New switches are primary-capable by default.Because stacks can consist of switches of different series and different models, ExtremeXOS does not restrict configuration settings based on the capabilities of any particular node in the stack. Therefore, you are responsible for ensuring that your configuration settings are appropriate for all switches in the stack.
The following switch families come from the factory with stacking-support enabled with stack ports set to a default configuration. The following table describes the default configuration for each switch:
| Switch | Stack port default configuration |
| 4120 | SummitStack V200 |
| 4220 | SummitStack V40 |
| 5320 | SummitStack V40 |
| 5420 | SummitStack V40 |
| 5520 | SummitStack V160 |
| 5720 | SummitStack V400 |
| 7520 | SummitStack V400 |
| 7720 | SummitStack V400 |
Important
Some ExtremeSwitching switches contain different types of EXOS images. ExtremeSwitching 5720, 7520, and 7720 require an onie_x86_64 image type. The 4220 Series, ExtremeSwitching 5320, 5320 extended temperature (XT), 5420, and 5520 require a summit_arm image type. The 4120 Series requires an rgz2 image type. Before building a mixed stack of these switch families, all switches must have the same release level image loaded onto all nodes.Once a mixed stack of ExtremeSwitching 5720 and ExtremeSwitching 5520 switch families has been built, a software upgrade is required. Download and install the onie-summitarm-bundle.lst image, which combines the onie_x86_64 image and the summit_arm image into one bundle.
Alternatively, you can use the following two step upgrade process:
Instructions for physically setting up the stack are provided in the hardware installation guide for your switch.
If the stack will use MPLS, only the 5520 switch can act as primary and backup.* switch1 # show stacking stack-ports Stack Topology is a Ring Slot Port Select Node MAC Address Port State Flags Speed ---- ---- ------ ----------------- ----------- ----- ----- *- 1 27 00:04:96:9c:e4:39 Operational C- 10G *- 2 28 00:04:96:9c:e4:39 Operational CB 10G - 1 27 00:04:96:9b:c1:34 Operational CB 10G - 2 28 00:04:96:9b:c1:34 Operational C- 10G - 1 15 00:04:96:9e:5c:76 Link Down C- 10G - 2 16 00:04:96:9e:5c:76 No-Neighbor C- 10G - 1 15 00:04:96:9c:53:b6 Operational C- 10G - 2 16 00:04:96:9c:53:b6 Operational C- 10G * - Indicates this node Flags: (C) Control path is active, (B) Port is Blocked
* 5420F-48P-4XE # show stacking configuration
Stack MAC in use: <none>
Node Slot Alternate Alternate
MAC Address Cfg Cur Prio Mgmt IP / Mask Gateway Flags Lic
*00:04:96:9c:e4:39 1 - Auto <none> <none> -c-----Nn --
00:04:96:9b:c1:34 1 - Auto <none> <none> -c-----Nn --
00:04:96:9e:5c:76 1 - Auto <none> <none> -c-----Nn --
00:04:96:9c:53:b6 1 - Auto <none> <none> -c-----Nn --
Flags: (C) master-Capable in use, (c) master-capable is configured,
(E) Stacking is currently Enabled, (e) Stacking is configured Enabled,
(M) Stack MAC in use, (m) Stack MACs configured and in use are the same,
(i) Stack MACs configured and in use are not the same or unknown,
(N) Enhanced protocol is in use, (n) Enhanced protocol is configured,
(-) Not in use or not configured
License level restrictions: (C) Core, (A) Advanced edge, or (E) Edge in use,
(c) Core, (a) Advanced edge, or (e) Edge configured,
5420F-48P-4XE.4 # enable stacking You have not yet configured all required stacking parameters. Would you like to perform an easy setup for stacking operation? (y/N)
Executing "configure stacking easy-setup" command... For every node in the 4-node stack, this command will: - enable stacking - configure a stack MAC address - choose and configure a slot number (this node will be assigned to slot 1) - configure redundancy to minimal (slot 1 will be the master node) - configure the stacking protocol to enhanced Upon completion, the stack will automatically be rebooted into the new configuration. Warning: If stacking is already configured, this command will alter that configuration. Do you wish to proceed? (y/N)
Enter y again to confirm. All of the switches reboot automatically and form a stack in which one switch is the primary, one is the backup, and the rest are standby nodes. Easy Setup configures all other required stacking parameters for every switch in the stack.
config_name.cfg to the NVRAM of each node.
